Iocage jails - Autostart doesn't (nightlies)
Tim1962
I'm running FreeNAS-11.2-MASTER-201808151301 nightlies but I think its been a while.
I have three iocage jails (urbackup, dokuwiki and nextcloud self installed)
Until recently they all autostarted if I rebooted but sometime in the last 2 weeks or so they don't autostart. Manually starting them works fine
Except Nextcloud that reports in the gui that its down yet is actually running??? (The others are down and aren't running.). Nextcloud can be made to start (even when running) but on page refresh reverts back to down status on the gui
Otherwise nothing noticeably changed
I'll probably just revert back to an earlier version if its just me unless I'm told its a bug and going to be fixed
Jailer
Not strong, but bad
If this is something that was working fine before and now it isn't you should file a bug report.
Tim1962
Bug #42359
