iocage import failing and causing swap error
Dperrigo
Hi. This is the first time I am posting here so I might do this wrong. Sorry.
I made a jail using the NextCloud plugin and got it up and running and put all my files on it. I decided to back it up and I found out that iocage export was a good solution to back up jails. I went to import it today so I could get some files that were deleted back and it didn't work, I checked the logs and it came up with swap_pager_getswapspace(2): failed like 50 times and the number changes then it kills the process.
I am not that in depth with how FreeNAS works and Ive tried to fix it for a while but I dont know what to do now.
Dperrigo
I meant to attach the log and messed up.
  • messages.txt
