iocage and Plex
Ismael Duarte
Hi!
Please give some tips about this, I'm doing something wrong.
I've successfully created an iocage with Apache, MySql and PHP, everything working.
I can install and run Plex, add media e configure.
The only issue is that plex can't get metadata for the movies (name, descriptions, tags, posters, ...).
I still have plex with warden template and, the same media, is fine.
Is this a bug? or I'm doing something wrong!?
nojohnny101
Your new icoage jail has internet access correct?
Ismael Duarte
Solved. Configuring vnet solved the issue. Don't know why because I had internet access with previous configuration.
Edit: NOT Solved. After a reboot, no more internet inside the iocage jail.
had to revert to old config.
This all as to do with network configuration
ryanakata
I plan on making a walkthrough to port over a warden jail config to a new iocage install. However at the moment with a newborn at the holiday time, I've only had one attempt at it with less than stellar results. Once I have some more time to tinker with it, I hope to have a full guide and pics available on the forum here. I tried following the resource that was created by Pentaflake but it threw a good bit of errors on me and plex never would start.
nojohnny101
This all as to do withnetwork configuration
Did you make those modifications via the CLI or GUI? I was under the impression that changes made via the CLI don’t survive a reboot as far as I know.
nojohnny101
CLI, but they do survive, thy're recorded in config.json.
You're correct. I just double-checked and it gives that warning once initially SSHing in, discouraging CLI modifications to FN's configuration, not the jails. Thanks.
