My old LSI SAS 2008 HBA started causing occasional pool corruption so I replaced it with a LSI SAS 2308 HBA. Since then I've had no further pool corruption issues. I've also added a fan to provide extra cooling for the 2308 as I think that's why the 2008 started having issues after many years of perfect service.
But now I'm running into the issue where sometimes when I restart my NAS I get the following error shortly after it finishes booting. This causes it to kick several drives from my pool, locking up TrueNAS.
Because it's locked up, I have to force power it off. However, if the box boots and I don't receive the error, everything works perfectly. It will run fine until i need to reboot. AFAICT, there's no pattern to the IOC Fault. Sometimes it happens, sometimes it doesn't. It hasn't caused any pool corruption and it only seems to happen within a couple minutes of finishing booting.
Any ideas what the issue could be? AFAIK, 20.00.07.0 is the latest firmware. I'm not sure why the Driver is 21.02.00.00-fbsd.
Thanks.
mps0: IOC Fault 0x40000d04, Resetting mps0: Reinitializing controller mps0: Firmware: 20.00.07.0, Driver: 21.02.00.00-fbsd
Thanks.
