I've just noticed these issues starting on my Truenas server. Im running Core 12.0 U8 on an HP Z840 with the built-in LSI HBA that I've flash to IT mode with the latest fw and bios. The drives connected to the HBA are two WD Red 6TB drives. They are the SMR drives unfortunately. My pool status shows as healthy and no smart errors on the drives.
I've been doing research and have found others with this issue on 12.0 U1 IIRC. There was a tuneable that seemed to correct the issue but Im not sure if that will help in my case.
Is my HBA dying or is this just an issue with freebsd?
Mar 20 17:52:57 FreeNAS mps0: IOC Fault 0x40000d04, Resetting
Mar 20 17:52:57 FreeNAS mps0: Reinitializing controller
Mar 20 17:52:57 FreeNAS mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd
Mar 20 17:52:57 FreeNAS mps0: IOCCapabilities: 5a85c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,MSIXIndex,HostDisc>
Mar 20 17:52:57 FreeNAS (da0:mps0:0:0:0): Invalidating pack
Mar 20 17:52:57 FreeNAS da0 at mps0 bus 0 scbus0 target 0 lun 0
Mar 20 17:52:57 FreeNAS da0: <ATA WDC WD60EFAX-68J 0A82> s/n WD-WX61DC94761J detached
Mar 20 17:53:05 FreeNAS GEOM_MIRROR: Device swap0: provider da0p1 disconnected.
Mar 20 17:53:05 FreeNAS (da0:mps0:0:0:0): Periph destroyed
Mar 20 17:53:05 FreeNAS da0 at mps0 bus 0 scbus0 target 0 lun 0
Mar 20 17:53:05 FreeNAS da0: <ATA WDC WD60EFAX-68J 0A82> Fixed Direct Access SPC-4 SCSI device
Mar 20 17:53:05 FreeNAS da0: Serial Number WD-WX61DC94761J
Mar 20 17:53:05 FreeNAS da0: 600.000MB/s transfers
Mar 20 17:53:05 FreeNAS da0: Command Queueing enabled
Mar 20 17:53:05 FreeNAS da0: 5723166MB (11721045168 512 byte sectors)
Mar 20 17:53:07 FreeNAS GEOM_ELI: Device mirror/swap0.eli destroyed.
Mar 20 17:53:07 FreeNAS GEOM_MIRROR: Device swap0: provider destroyed.
Mar 20 17:53:07 FreeNAS GEOM_MIRROR: Device swap0 destroyed.
Mar 20 17:53:07 FreeNAS GEOM_MIRROR: Device mirror/swap0 launched (2/2).
Mar 20 17:53:07 FreeNAS GEOM_ELI: Device mirror/swap0.eli created.
Mar 20 17:53:07 FreeNAS GEOM_ELI: Encryption: AES-XTS 128
Mar 20 17:53:07 FreeNAS GEOM_ELI: Crypto: hardware
