I have a CRON job running on my TrueNAS that watches a few of the key SMART
parameters on my boot drives. The count on each of the following parameters:
168|SATA_Phy_Error_Count
218|CRC_Error_Count
incremented by 1 on each of July 13, 14, 15, 19 and 21.
The counts are not super high:
168|SATA_Phy_Error_Count|32
218|CRC_Error_Count|32
but I'm pretty sure some sort of preemptive maintenance is in order.
My boot pool is a mirror of two budget 120GB SSDs running off of
SATA ports on the Motherboard. I have the system database on the
boot pool since I want the system to be functional without the data
pool if I want to troubleshoot the system with the data pool drives
removed.
The drive showing the errors is a KINGSTON Model# SA400S37120G
(Smart Info at the end of this post.)
The other drive is older and is an HP S700 120GB SSD that seems to be
fine.
IIUC this could be a drive problem, a cable probem, a (Motherboard) SATA
Port problem or a powersupply problem.
My question is how to troubleshoot given the intermittent nature of the
problem. Any suggestions would be much appreciated.
DMESG entries pertaining to the fault.
218|CRC_Error_Count
removed.
fine.
(ada3:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 d0 20 c3 7c 40 04 00 00 00 00 00 (ada3:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error (ada3:ahcich5:0:0:0): Retrying command, 3 more tries remain (ada3:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 30 08 cb b3 40 04 00 00 00 00 00 (ada3:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error (ada3:ahcich5:0:0:0): Retrying command, 3 more tries remain (ada3:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 20 20 9b ae 40 04 00 00 00 00 00 (ada3:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error SMART Output for drive:smartctl -x /dev/ada3 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Phison Driven SSDs Device Model: KINGSTON SA400S37120G Serial Number: REDACTED LU WWN Device Id: 5 0026b7 782ea1dc1 Firmware Version: S3500102 User Capacity: 120,034,123,776 bytes [120 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device TRIM Command: Available Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 4 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Jul 22 03:23:00 2022 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Disabled Rd look-ahead is: Enabled Write cache is: Enabled DSN feature is: Unavailable ATA Security is: Disabled, frozen [SEC2] Wt Cache Reorder: Unavailable === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x02) Offline data collection activity was completed without error. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 120) seconds. Offline data collection capabilities: (0x11) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0002) Does not save SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 10) minutes. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate -O--CK 100 100 000 - 100 9 Power_On_Hours -O--CK 100 100 000 - 21839 12 Power_Cycle_Count -O--CK 100 100 000 - 31 148 Unknown_Attribute ------ 100 100 000 - 0 149 Unknown_Attribute ------ 100 100 000 - 0 167 Write_Protect_Mode ------ 100 100 000 - 0 168 SATA_Phy_Error_Count -O--C- 100 100 000 - 33 169 Bad_Block_Rate ------ 100 100 000 - 0 170 Bad_Blk_Ct_Erl/Lat ------ 100 100 010 - 0/0 172 Erase_Fail_Count -O--CK 100 100 000 - 0 173 MaxAvgErase_Ct ------ 100 100 000 - 0 181 Program_Fail_Count -O--CK 100 100 000 - 0 182 Erase_Fail_Count ------ 100 100 000 - 0 187 Reported_Uncorrect -O--CK 100 100 000 - 0 192 Unsafe_Shutdown_Count -O--C- 100 100 000 - 19 194 Temperature_Celsius -O---K 044 062 000 - 44 (Min/Max 31/62) 196 Reallocated_Event_Count -O--CK 100 100 000 - 0 199 SATA_CRC_Error_Count -O--CK 100 100 000 - 0 218 CRC_Error_Count -O--CK 100 100 000 - 33 231 SSD_Life_Left ------ 090 090 000 - 90 233 Flash_Writes_GiB -O--CK 100 100 000 - 8865 241 Lifetime_Writes_GiB -O--CK 100 100 000 - 12051 242 Lifetime_Reads_GiB -O--CK 100 100 000 - 2641 244 Average_Erase_Count ------ 100 100 000 - 202 245 Max_Erase_Count ------ 100 100 000 - 222 246 Total_Erase_Count ------ 100 100 000 - 40787 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 1 Comprehensive SMART error log 0x03 GPL R/O 1 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xde GPL VS 8 Device vendor specific log SMART Extended Comprehensive Error Log Version: 1 (1 sectors) Device Error Count: 33 (device log contains only the most recent 4 errors) CR = Command Register FEATR = Features Register COUNT = Count (was: Sector Count) Register LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8 LH = LBA High (was: Cylinder High) Register ] LBA LM = LBA Mid (was: Cylinder Low) Register ] Register LL = LBA Low (was: Sector Number) Register ] DV = Device (was: Device/Head) Register DC = Device Control Register ER = Error register ST = Status register Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 33 [0] log entry is empty Error 32 [3] log entry is empty Error 31 [2] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 04 -- 51 00 00 00 00 00 00 00 00 40 00 Error: ABRT Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- b0 00 d1 01 01 00 00 4f 00 c2 01 40 08 00:00:00.000 SMART READ ATTRIBUTE THRESHOLDS [OBS-4] 2f 00 00 01 01 00 00 00 00 00 03 40 08 00:00:00.000 READ LOG EXT 2f 00 00 01 01 00 00 00 00 00 00 40 08 00:00:00.000 READ LOG EXT b0 00 d5 01 01 00 00 4f 00 c2 00 40 08 00:00:00.000 SMART READ LOG b0 00 da 00 00 00 00 4f 00 c2 00 40 08 00:00:00.000 SMART RETURN STATUS Error 30 [1] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 04 -- 51 00 00 00 00 00 00 00 00 40 00 Error: ABRT Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- b0 00 d1 01 01 00 00 4f 00 c2 01 40 08 00:00:00.000 SMART READ ATTRIBUTE THRESHOLDS [OBS-4] 2f 00 00 01 01 00 00 00 00 00 03 40 08 00:00:00.000 READ LOG EXT 2f 00 00 01 01 00 00 00 00 00 00 40 08 00:00:00.000 READ LOG EXT b0 00 d5 01 01 00 00 4f 00 c2 00 40 08 00:00:00.000 SMART READ LOG b0 00 da 00 00 00 00 4f 00 c2 00 40 08 00:00:00.000 SMART RETURN STATUS SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 21598 - # 2 Extended offline Completed without error 00% 21591 - # 3 Extended offline Completed without error 00% 20707 - # 4 Extended offline Completed without error 00% 18218 - # 5 Extended offline Completed without error 00% 13958 - # 6 Extended offline Completed without error 00% 7400 - # 7 Extended offline Completed without error 00% 6975 - # 8 Extended offline Completed without error 00% 1348 - # 9 Extended offline Completed without error 00% 0 - #10 Short offline Completed without error 00% 0 - Selective Self-tests/Logging not supported SCT Commands not supported Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 1) == 0x01 0x008 4 31 --- Lifetime Power-On Resets 0x01 0x010 4 21839 --- Power-on Hours 0x01 0x018 6 3799441290 --- Logical Sectors Written 0x01 0x020 6 9010952 --- Number of Write Commands 0x01 0x028 6 1245637882 --- Logical Sectors Read 0x01 0x030 6 1333687 --- Number of Read Commands 0x07 ===== = = === == Solid State Device Statistics (rev 1) == 0x07 0x008 1 22 --- Percentage Used Endurance Indicator |||_ C monitored condition met ||__ D supports DSN |___ N normalized value Pending Defects log (GP Log 0x0c) not supported SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 4 7 Command failed due to ICRC error 0x0002 4 7 R_ERR response for data FIS 0x0005 4 0 R_ERR response for non-data FIS 0x000a 4 18 Device-to-host register FISes sent due to a COMRESET
