interrupt21h
- Oct 16, 2016
My FreeNAS box (ASRock C2750D4I, 16gb ECC memory) has been running flawlessy for the last six months. I have a mirrored pool of 4 x 4TB Seagate NAS drives.
I'm new to ZFS but have some experience with *nix systems.
Three days ago I received the following error by email:
So I checked the pool status to confirm and ada2 was offline. At first I thought the drive prematurely died on me but I first swapped the drive in another bay and rebooted the system. No error occured and the pool showed as Healthy.
To verify data integrity I did a scrub during the night and midway through it another critical error occured and the pool once again showed as degraded.
I have short SMART tests enabled every 30 minutes but realized that I never scheduled long SMART tests.
So I ran a long test and then I checked the SMART status but I am not super comfortable interpreting them. There's no reallocated sector showing in the SMART status.
After all that I rebooted the server one last time one day ago and no error occured ever since.
I have read https://forums.freenas.org/index.php?threads/is-my-drive-going-bad.42742/
and
https://forums.freenas.org/index.php?threads/critical-alert-how-best-to-proceed.30645/
Is that a sign the the drive will likely fail soon or there's another more likely cause? Internal SATA cabling? Why would it be intermittent?
I Also realized in all this process that I had no spare drive at home so I'll go and buy one. Should I replace the drive that caused thos critical errors?
What are the advantages/disadvantages of running a hot spare vs having the spare drive sit quietly in my closet? I still have 4 bays available in my chassis.
Thanks for your help
The volume data (ZFS) state is DEGRADED: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state. Device: /dev/ada2, unable to open device
pool: data state: DEGRADED status: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. action: Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'. see: http://illumos.org/msg/ZFS-8000-9P scan: scrub repaired 51.4M in 2h46m with 0 errors on Sun Oct 16 01:32:55 2016 config: NAME STATE READ WRITE CKSUM data DEGRADED 0 0 0 mirror-0 ONLINE 0 0 0 gptid/99c05557-f6ca-11e5-be76-d05099c08a48 ONLINE 0 0 0 gptid/9a69f4f8-f6ca-11e5-be76-d05099c08a48 ONLINE 0 0 0 mirror-1 DEGRADED 0 0 0 gptid/9b18fd4a-f6ca-11e5-be76-d05099c08a48 ONLINE 0 0 0 gptid/9bcdc0e4-f6ca-11e5-be76-d05099c08a48 DEGRADED 0 0 12.7K too many errors errors: No known data errors pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h3m with 0 errors on Mon Oct 3 03:48:43 2016 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate NAS HDD Device Model: ST4000VN000-1H4168 Serial Number: Z304WQNB LU WWN Device Id: 5 000c50 086e996b2 Firmware Version: SC46 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5900 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Oct 17 18:09:40 2016 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 107) seconds. Offline data collection capabilities: (0x73) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 485) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x10bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 117 100 006 Pre-fail Always - 157170104 3 Spin_Up_Time 0x0003 091 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 22 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 063 060 030 Pre-fail Always - 8594435583 9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3780 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 22 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 066 057 045 Old_age Always - 34 (Min/Max 21/40) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 0 193 Load_Cycle_Count 0x0032 014 014 000 Old_age Always - 173479 194 Temperature_Celsius 0x0022 034 043 000 Old_age Always - 34 (0 18 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 ATA Error Count: 1 CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 1 occurred at disk power-on lifetime: 3742 hours (155 days + 22 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 71 03 80 04 11 40 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ea 00 00 00 00 00 40 00 12d+17:31:00.627 FLUSH CACHE EXT 61 00 08 ff ff ff 4f 00 12d+17:31:00.609 WRITE FPDMA QUEUED 61 00 28 ff ff ff 4f 00 12d+17:30:57.234 WRITE FPDMA QUEUED 61 00 18 ff ff ff 4f 00 12d+17:30:57.233 WRITE FPDMA QUEUED 61 00 10 ff ff ff 4f 00 12d+17:30:57.233 WRITE FPDMA QUEUED SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 3765 - # 2 Short offline Completed without error 00% 3596 - # 3 Short offline Completed without error 00% 3584 - # 4 Short offline Completed without error 00% 3411 - # 5 Short offline Completed without error 00% 3399 - # 6 Short offline Completed without error 00% 3243 - # 7 Short offline Completed without error 00% 3231 - # 8 Short offline Completed without error 00% 3075 - # 9 Short offline Completed without error 00% 3063 - #10 Extended offline Completed without error 00% 3010 - #11 Short offline Completed without error 00% 2907 - #12 Short offline Completed without error 00% 2895 - #13 Short offline Completed without error 00% 2739 - #14 Short offline Completed without error 00% 2727 - #15 Short offline Completed without error 00% 2571 - #16 Short offline Completed without error 00% 2559 - #17 Short offline Completed without error 00% 2309 - #18 Short offline Completed without error 00% 2297 - #19 Short offline Completed without error 00% 2141 - #20 Short offline Completed without error 00% 2129 - #21 Short offline Completed without error 00% 1973 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
and
