jjstecchino
- May 29, 2011
This weekend I wanted to try Scale on my hardware running Truenas 12 U1.
The setup I like is booting in EFI mode from 2 mirrored usb flash drives.
I do this as the usb drives act as physical keys for my nas. If I turn of the system and remove the keys, my encrypted pools would remain unaccusable to anybody.
And for the curious... yes I keep the pool keys backed up somewhere else as well. So if the event both usb flash fail simultaneously nothing is lost other than time recreating the system.
I wanted to replicate this setup with scale.
The installer seems to allow the creation of a mirrored boot drive allowing you to select multiple disks, however it doesn't show my 2 installed flash drives. I dont know if it is a bug or is it by design as I realized booting from usb flash it is frowned upon.
If I drop to a console I can see and access the flash drives.
It would be very nice to be able to continue using usb drives if possible. Is there any workaround?
