freebsd-server-configurator
- Aug 22, 2020
I wan't to install nextcloud via terminal.
For that I use the supposed way here: Install nextcloud
At one moment, you need a database. In the example another jail with mariadb. I follow the instruction there Install mariadb
Now I have a problem: When I execute in my iocage, I receive an error like
I searched on the place /var/run/mysql.sock for some data. There is none...
Two things:
mysql_secure_installation
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysql/mysql.sock' (2)
Two things:
- Maybe my.cnf under /var/db/mysql/my.cnf is not correct. I used the same as suggestet in the manuel.. Should work, or?
- I wonder why, no data mysql.sock exists... What can i do to "see" this file?
