SOLVED Installing 11 RC1, SanDisk Ultra Fit device not listed as possible destination devices
darthvader42
I'm trying to install 11 RC1. I have Asrock C2550D4I based box having 4 harddiscs and 2 ssds. FreeNAS should be installed to a plugged SanDisk Ultra Fit, installation iso image is copied to a USB key (Toshiba TransMemory).
Both USB devices are properly detected, SanDisk is da0, Toshiba is da1, see camcontrol devlist output
3xuA9HCigvP8thF04iCnctUAjlOgoH2_pSv7-DPAuhHV1JxLTgmFeIY6sAm7gnDUTFIkeDIYo4EK2G-ncjRPuibfIYzHGoR4SlYG_IllZNyxtocEbuoVU0SQrgho09n8wnfRsYmtxHcnc6SIVdXUgkz7e_EeJaBIbb25O6N3HBHp5mTR8sSNPAz33s0flI7RWX80LGrfBt5jjCiLT-jmmTrKLZJ1dgOX5eRnzxzRyxoVDyHp0UET6PyBdmwTqisz6nOMztJ3ljz_ulRn0ZKzA2NwXdFCYTJ_bgha2ifGus7tjXj_Pk94Il_16GQRZVuvbYvH2pYD0-gYI10SqK56BRSpFlzd9aWGAyn4WvA4XroPYMcZxJ08FT_rrS8uq7WWla-FMi5u8Y57yAWc0wVxaYxBlEw8JxAjhDSkpkf21U9mzcHV10ir_0JhrEH8oWJmIeoGaG_sQJDVvSXQZdUpv6qAdVBDmp7H094rLbN9WBBn4eOh7ohRyU_1Kv2SuoRrVSVS2Bg0OtiHVOnqEzNJ8wayqyzVtXhnWZResEcPAYBmGnJTL5Q68DC5PWqBp2zFLouI2w11r2NXgQAdGN0YuZkKo7qVYqbPc23uNJJ9tjHX3yq0ZD5b=w1703-h1277-no
Upon install only the Toshiba device is listed as target device but not the SanDisk one, see
_X3rBRnmuvj4_elI3ZpQfCRiDDUhuAOSmZvLSCHEGTvTc4df4lvSg-46oVHEdzVFETrjAk3bO7wvG-e_3igzEmk4njJpqPgiLW0BKy5NRxUxff-QXaAUxjW-vVBjkRS8LGAI0ZH1XBA0tXhF9L-bFzw5r4vwWrHkTxssAnMvsV8AZKG579TOzJiaXy-UC5VfuvG1IcFMwCwraSiZdIB1x6xaatUBFfBkojnoW9RN-yFdEAVvDZmuM_N47LgdU71TDWyH-3s4n0z6QosyAT6NZUoRmezWzKmFh8Ryjq3_-l7OEQ_IY4wzPJhBMt88JJnpQN8B8fS5hxtxbR9pm4RNhYjLJBYZ6eNkwwW17uyK5tFWpM094VjDv80caviq-ACmS585kRX7CekMACOl67ndjnt6IC-FCIRTq633cago1T2b3FXMiX0lG7cG3Pv6uV9Ii8X7FVEy9YA4JuYyaWIE8Jfu_TTfEGTfxx5EDh6sIVZqGId31TCoPvL3MO5TxhGe7GceKbMVt730lS5-TZYzUl2zsvXlBnj7gNxwCpwrxlbM19T-3AcZ9TcvjU7jQ0bRPL5iMza0T2I_6zfnOrGZu3vsW8V1ZUHyV5J7fdurfCDiq9De=w1703-h1277-no
Why doesn't it bring up da0 as potential destination device. The SanDisk device contains a single partition formatted with mkfs.vfat (done on Linux). Any hints?
scurrier
Is the SandDisk device USB 3? One shot in the dark would be to consider if USB 3 is causing some issues here. There may be some BIOS settings dealing with USB 3 boot devices that you might have to enable. Or UEFI settings.
Maybe it's the partitioning that's throwing off the installer.
darthvader42
Indeed there was some partitioning messup on the USB device.
On Linux I've used
wipefs --all /dev/sd[myname]
to clean it up.
And it worked normally from there?
darthvader42
Yup, the `wipefs` command helped. Afterwards I've used `fdisk` to create one single partition occupying the full USB key and run a `mkfs.vfat` on it.
wblock
Documentation Engineer
That is not necessary.
