Installation of additional utilities
IanWorthington
Hi.
I need to install hashdeep on my FreeNAS.
Is it advisable to create a jail for such tools, and if so, will that survive a freenas upgrade? Or should I just add this to the base?
i
IanWorthington
I need to use a tool that will also run on Windows.
So I've created a standard jail and I think I need to add storage to it, to access the zfs files outside of the jail, right? But I get this message:
but I think this is already set:
solarisguy
I have no idea about the details or internals of your issue.
However it seems that: your Jail is not Ian, and it does not belong to group Ian... So unless you change either ownership or add Other permissions you will be getting the message in red.
AlainD
Hi
How did you get an executable for hashdeep?
I use it on windows and having it on my freenas as a command would be nce.
Alain
AlainD
Just a reminder. How to get an executable for hashdeep to use on freenas?
depasseg
FreeNAS Replicant
In a jail, have you tried to run "pkg install hashdeep"?
