Dear FreeNAS users, admins and wizards,
I, finally, started to create my home NAS, run through many pros and cons and chose ZFS and hence FreeNAS.
I'm using mother board ASRosk J4205 with preinstalled processor, booting from flash drive (image FreeNAS-11.1-RELEASE.iso).
HDD 250Gb with some partitions on ext4 is in SATA slot for the installation to test, assume it's going to be re-partitioned by installer.
after grub I got error "unknown: I/O range not supported":
should I destroy partitions on the HDD or the motherboard is not supported yet?
thank you!
and Mery Christmas :)
thank you!
