Installation ASM 1061 sata controller
alcutri
Hi, I´m having problem to install the SATA PCI card ASM 1061 in the FREENAS, the pci card don´t work, Anybody help me?
See bellow display comand pciconf and camcontrol:
[root@freenas] ~# camcontrol devlist (here should display more 2 HD´s)
<TSSTcorp DVD-ROM TS-H352C DE02> at scbus2 target 0 lun 0 (cd0,pass0)
<WDC WD1600YS-18SHB1 20.06C06> at scbus3 target 0 lun 0 (ada0,pass1)
[root@freenas] ~# pciconf -lbv
atapci0@pci0:11:0:0: class=0x010185 card=0x10601b21 chip=0x06111b21 rev=0x01 hdr=0x00
vendor = 'ASMedia Technology Inc.'
class = mass storage
subclass = ATA
bar [10] = type I/O Port, range 32, base 0xccf8, size 8, enabled
bar [14] = type I/O Port, range 32, base 0xccf0, size 4, enabled
bar [18] = type I/O Port, range 32, base 0xcce0, size 8, enabled
bar [1c] = type I/O Port, range 32, base 0xccd8, size 4, enabled
bar [20] = type I/O Port, range 32, base 0xccc0, size 16, enabled
bar [24] = type Memory, range 32, base 0xfc4efc00, size 512, enabled
Thank´s
You'll need to find the chipset on that card and see if it's supported in FreeNAS.
$100 says it's not supported though.
There's a whole bunch.. check out our hardware recommendation sticky.
