Input/Output error on storage drive
I am having problems with one of my drives on my TrueNAS Scale. My hardware configuration is:
My hardware:
OS Version:TrueNAS-SCALE-22.12.4.2
Product:HP Compaq 6200 Pro MT PC
Model:Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
Memory:19 GiB
3 Drives:
    SDA: 500GB / Storage Drive
    SDB: 1TB / Storage Drive
    SDC: 250GB / Boot Drive
There is no mirroring configuration all drives are working independently. The device failing is /dev/sdb.
I have attached the truenas logs and the results of smartctl -a.
  • drive-failure-a.txt
  • drive-failure-logs.txt
According to smartctl, your drive had a bunch of issues trying to read some data (which would line up directly with an I/O error reported by TrueNAS) which happened about 200 hours after your last extended test (which was your only test in the last ~10K hours of running).
I would suggest another extended test will show more than the last one.
You're saying you have no redundancy it seems, so unless you can copy all important data off that pool, you're going to lose some data.
Thank you very much @sretalla,
I have ran an extended test which result I am attaching here. I am hoping to retrieve at least part of the information stored in the drive so I will appreciate any ideas as I am a total newbie with Truenas.
  • drive-failure-a-1.txt
