- Mar 6, 2014
Experimental support for time machine over SMB is in FreeNAS 11.1-U5 and 11.1-U6
Step 1: enable "vfs_fruit" on ALL SMB shares. This is _required_ because OS-X SMB clients negotiate support for the SMB2_AAPL protocol extensions on the first SMB2 tree connect.
Step 2: Add auxiliary parameter "fruit:time machine = yes" to the SMB share you want to use for time machine backups.
Step 3: Restart samba in the UI (not the command line. we need to properly restart mdns as well as samba)
Caveats:
a) you may need to disable time machine over AFP
b) you may need to mount the SMB share before it will appear as a backup target.
c) this feature has not been robustly QA-ed yet, but feel free to take it for a spin.
Caveats:
