x130844
- Oct 25, 2020
any idea why, or how I could debug this?
If I add a mount command in my init/shutdown task like:
zpool import backup-drive
it simply fails to start the VM automatically.
If I start them manually, it works. There's something during the boot but unsure where I'd find that info.
dmesg doesn't show anything
and nothing in /var
A post init script like pool import should not impede my vm to autostart. Right?
Note that if the init command is set in the console as pre-init. it works fine, which makes no sense to me. post-init should work.
and nothing in /var
