INIT: NOT FOUND IN PATH... ENTER: PANIC
Rovin Hood
please help me!! after successfully installed freenas and rebooted my system, Here is the part where
it stops during boot up. I installed freenas 9.10 stable and 9.3 release but the same problem occur as
as shown in the screenshot below. Any solutions please? this is for the file server in my company that
needs to be accessed everyday. Thanks to support and assist.
8Xvq_liJhPMqsm36YDheTjgwqFzWKPDONXV9CPNLTp7ewOZXgWljJ0sDtsdrBUsWubLfiMnp265Lmrdu_h727jBxxHwTQnKcu_35xzfY9KjNNXGwiCWSc8YlZ3R0ZTLhEpk0YT2u6ZD6lnXcvdbwHA4m4nwA741q7dzhV-sPTG7CCvXZ8DxAPC2x92Z1PCoLRTNksQHjU7L-FqLtLDbWbouT2UKekiemFsaW3_WeUnAQxrOuQsb9IFYwDFaJ6hJbfAGtVqxc8GJZ_hsEUczLEjNGADCmVXy8282iKB6mDwest4QqJ4qM0VuDqjtckFB61CG-3JUED9J4iKnws-ZJMmUTstLszUC511UUuy08fLojaieNbJo8bFxxn4IZOcWIkCoD2EBfF8Pbls0MiLta4Bgz2_MhAQAygm9SyYKsgrfeW_o18C09c5JgR5NWcaCTPJl39XBvwVjX-fQ0cm1ZyeojtYYfLsW3QcZBgRGzZkPmH5Ln6VWGsIP6yNywISFUUJkzzv1-4SORLUdiuuloS8IMALFDkS2iCJ9mRBiCipiyznTLxgBSG3p18vSg05CZ_i0=w562-h316-no
-Rovin Hood
DrKK
FreeNAS Generalissimo
We need to know the details of the hardware. What CPU? What motherboard? How much RAM and of what type? What are you using for your boot device exactly? etc.
Rovin Hood
Hi DrKK,
Here is my system specs:
Intel Core i-5 4460
Asus H81MD Motherboard
Kingston 4GB 1333 (x2)
Seagate 2.0TB SATA
Basic CPU Casing w/ 600w PSU
Thanks for assistance.
-Rovin Hood
DrKK
It appears that the files that are supposed to be in various locations on the boot media are not there. To me, that means that either your boot drive is broken in some strange way, or, you did not install the FreeNAS boot image on the thumb drive correctly.
Maybe someone else will have an idea.
Also, that's not good hardware for FreeNAS.
Rovin Hood
I used another HDD where i installed the FreeNAS OS instead of a flash drive. So therefore HDD1=FreeNAS OS,
HDD2=Storage. Is that okay?
jgreco
Resident Grinch
It doesn't seem to have worked. Perhaps it would be a good idea to try reinstalling it. In theory it's fine to install to a hard disk. The OS doesn't actually care.
maglin
I would use this opportunity to get your company to purchase some better hardware. For about $2k you can have a very decent system.
Just reinstall. Do you only have one HDD for storage? Are you installing the OS to the array or a dedicated HDD?
