cmfisher4
- Oct 8, 2013
All,
A bit of a lead-in to start: I've been trying to digest as much as possible on these forums and get an idea for a solid home FreeNAS build. I've been convinced on ECC RAM and RaidZ2 and all of the hardware need to support this. Currently, I do not have existing hardware to build that server, but I do have hardware sufficient to build a server. Right now, I'm running a Windows 8-based "server" (hey, it was easy and cheap) and would like to incrementally build my way to FreeNAS nirvana. I got lucky without knowing it and run a i3-3220 (yea ECC-support) for the Win8 build and, based on my current and perceived future needs, plan on sticking with it. I am pretty religious about running backups (I used two separate hard drives that back up my important stuff daily (alternating) using CrashPlan) and would be willing to risk the server going down (backups covering me as much as possible) while I slowly migrate to the system I eventually want.
So, after all of that, my question is should I wait until I have enough $$ and buy everything in one shot, or can I get away with a more incremental build? I was thinking of first purchasing the Mobo (Supermicro X9SCM-F) and a single stick of solid 8GB ECC RAM (narrow this down with a bit more research and I understand dual sticks is better, but don't want to do 2x4GB and then limit myself in the long run). I would use my existing i3, hard drives (2X 2TB consumer), case, etc. I would then probably go with the second 8GB stick and the 4 NAS drives (3 or 4TB, not sure yet). My biggest concern would be the change out of hardware and screwing up FreeNAS (like you can screw up Windows when you change out major pieces of hardware).
Curious of what you guys think and I want to thank everyone for all of their input over the entire forum. Awesome wealth of knowledge and opinions.
Thanks,
Chris
Thanks,
Chris
