adrianwi
- Oct 15, 2013
I've got a little bit of time off so thought it would be a perfect opportunity to rebuild my main FreeNAS box (APE1) with a few more disks. It's running with 7x4TB at the minute in RAIDZ2 and I'm at 70% full. I have periodic snapshots setup and a nightly replication to a 2nd FreeNAS box (APE2) with 5x4TB drives in a stripe.
I've added another 2x4TB drives into APE1 and realise I'll need to destroy the existing pool and recreate with a 9x4TB RAIDZ2 pool, but need to be able to replicate back from APE2 keeping all the configuration and jails working on APE1.
I'd bookmarked this thread > https://forums.freenas.org/index.ph...te-data-from-one-pool-to-a-bigger-pool.40519/ hoping I could do something similar, but don't have enough ports to do it all within one box.
I don't use APE2 for anything other than a backup, but thought I'd test to see what happened to the jails that are replicated across. I pointed the jail configuration root to the /mnt/APE2pool/jails dataset and all of the jails appears in the jails list. When I try and access the jail shell though, it just flashes up and closes down, so I guess something is missing from the replication between APE1 to APE2 and I'll need to keep this from APE1 before I destroy the pool, so I can put it back.
Any idea on the best way to achieve this so I don't have to rebuild the jails again on APE1 would be much appreciated.
Thanks
UPDATE:
I thought I'd reboot APE2 and I can now start a jail and access the shell. Tested Plex and ownCloud and other than mounting some datasets to the jails and adding the new IP address as a trusted domain for ownCloud everything appears to work!
Other suggestions and tips as to the best way to do this would still be good...
Thanks
UPDATE:
