I'm running into a strange issue with timestamps when trying to copy/backup files from my Mac to a shared drive on TrueNas.
My drive is defined in TrueNAS as a Home Share and mounted in MacOS via the Finder:
However, when I attempt to rsync, I get the creation date in my mount wrong:
As you can see using rsync, the created timestamp is incorrect in the Volume mount (the TrueNAS mount)
However, this is the strange thing, if I do the same thing with cp -P, the timestamp is maintained:
As you can see, the second file (_002.jpg) has the correct timestamp copied, whereas the first one does not.
Any ideas what might be the issue or how I can debug this timestamp issue?
Thanks,
Eric
> mount //eric@truenas._smb._tcp.local/eric on /Volumes/eric (smbfs, nodev, nosuid, mounted by via)
macos > ls -lt 20180210_120110_001.jpg -rw-r--r-- 1 via staff 723237 7 Jun 2018 20180210_120110_001.jpg macos > rsync -avztUN 20180210_120110_001.jpg /Volumes/eric/Pictures/Galaxy\ S21/2023-05-19/DCIM/Camera sending incremental file list 20180210_120110_001.jpg sent 663,066 bytes received 35 bytes 1,326,202.00 bytes/sec total size is 723,237 speedup is 1.09 macos > ls -lt /Volumes/eric/Pictures/Galaxy\ S21/2023-05-19/DCIM/Camera total 1326 -rwx------ 1 via staff 723237 23 May 2023 20180210_120110_001.jpg
macos >ls -lt 20180210_120110_002.jpg -rw-r--r-- 1 via staff 687066 7 Jun 2018 20180210_120110_002.jpg macos >cp -p 20180210_120110_002.jpg /Volumes/eric/Pictures/Galaxy\ S21/2023-05-19/DCIM/Camera macos >ls -lt /Volumes/eric/Pictures/Galaxy\ S21/2023-05-19/DCIM/Camera total 2583 -rwx------ 1 via staff 723237 23 May 09:17 20180210_120110_001.jpg -rwx------ 1 via staff 687066 7 Jun 2018 20180210_120110_002.jpg
Thanks,
Eric
