I can't wipe my 3 disks on freenas.
Each time, i obtain this message:
Error: Failed to wipe ada1: dd: /dev/ada1: Operation not permitted
What can i do to solve the problem.
I understand that there is some residu on the disks, but i've not found any solution.
Thanks.
Add logs:
Thanks.
Add logs:
Jul 12 14:09:27 freenas notifier: 1048576 bytes transferred in 0.550470 secs (1904874 bytes/sec)
Jul 12 14:09:27 freenas notifier: dd: /dev/ada4: short write on character device
Jul 12 14:09:27 freenas notifier: dd: /dev/ada4: end of device
Jul 12 14:09:27 freenas notifier: 5+0 records in
Jul 12 14:09:27 freenas notifier: 4+1 records out
Jul 12 14:09:27 freenas notifier: 4284416 bytes transferred in 0.075934 secs (56422943 bytes/sec)
Jul 12 14:09:36 freenas kernel: GEOM_ELI: Device ada4p1.eli created.
Jul 12 14:09:36 freenas kernel: GEOM_ELI: Encryption: AES-XTS 256
Jul 12 14:09:36 freenas kernel: GEOM_ELI: Crypto: software
Jul 12 14:09:36 freenas notifier: Mounting late file systems:.
Jul 12 14:09:37 freenas notifier: Stopping collectd.
Jul 12 14:09:38 freenas notifier: Waiting for PIDS: 2166.
Jul 12 14:09:38 freenas notifier: Starting collectd.
Jul 12 14:15:09 freenas notifier: gpart: geom '/dev/ada1': Invalid argument
Jul 12 14:15:09 freenas notifier: gpart: geom 'ada1': Operation not permitted
Jul 12 14:15:09 freenas manage.py: [middleware.exceptions:38] [MiddlewareError: Failed to wipe ada1: dd: /dev/ada1: Operation not permitted ]
Jul 12 14:15:10 freenas manage.py: [storage.views:996] Could not check for disk wipe progress: [Errno 3] No such process
Jul 12 14:15:12 freenas last message repeated 2 times
Jul 12 23:16:25 freenas notifier: Stopping ntpd.
Jul 12 14:16:25 freenas ntpd[1770]: ntpd exiting on signal 15
Jul 12 23:16:25 freenas notifier: Starting ntpd.
Jul 12 23:16:25 freenas ntpd[3376]: ntpd 4.2.4p5-a (1)
Jul 12 23:16:33 freenas ntpd[3377]: kernel time sync status change 2001
Jul 12 23:17:01 freenas manage.py: [storage.views:996] Could not check for disk wipe progress: [Errno 3] No such process
Jul 12 23:17:01 freenas notifier: gpart: geom '/dev/ada1': Invalid argument
Jul 12 23:17:01 freenas notifier: gpart: geom 'ada1': Operation not permitted
Jul 12 23:17:02 freenas manage.py: [middleware.exceptions:38] [MiddlewareError: Failed to wipe ada1: dd: /dev/ada1: Operation not permitted ]
Jul 12 23:17:02 freenas manage.py: [storage.views:996] Could not check for disk wipe progress: [Errno 3] No such process
Jul 12 23:17:04 freenas last message repeated 2 times
