Hi everyone
I have an 8.3 release on an amd x64 which fails to start the webgui. I rebooted today to replace a failed drive in a zraid and what I did, though I doubt it that it has anything with my issue, was offlined the disk from the webgui, shut the machine down and physically replaced the disk and once it booted back up again I ran into all sorts of errors. I also tried to delete/recreate the nginx files by doing:
# rm /usr/local/etc/nginx/nginx.conf*
# service ix-nginx start
# nginx
Below is the log, if someone can give me a hand here. Thank you.
# nginx
May 20 15:43:45 nas.local syslogd: restart May 20 15:43:45 nas.local syslogd: kernel boot file is /boot/kernel/kernel May 20 15:43:46 nas.local kernel: Setting hostuuid: 00020003-0004-0005-0006-00070008009. May 20 15:43:46 nas.local kernel: Setting hostid: 0x81f4ec68. May 20 15:43:46 nas.local kernel: /dev/ufs/FreeNASs4: FILE SYSTEM CLEAN; SKIPPING CHECKS May 20 15:43:46 nas.local kernel: /dev/ufs/FreeNASs4: clean, 37750 free (30 frags, 4715 blocks, 0.1% fragmentation) May 20 15:43:46 nas.local kernel: Traceback (most recent call last): May 20 15:43:46 nas.local kernel: File "/usr/local/www/freenasUI//notifier.py", line 42, in <module> May 20 15:43:46 nas.local kernel: May 20 15:43:46 nas.local kernel: import libxml2 May 20 15:43:46 nas.local kernel: ValueError May 20 15:43:46 nas.local kernel: : May 20 15:43:46 nas.local kernel: bad marshal data (unknown type code) May 20 15:43:46 nas.local kernel: May 20 15:43:46 nas.local kernel: Traceback (most recent call last): May 20 15:43:46 nas.local kernel: File "/usr/local/www/freenasUI//notifier.py", line 42, in <module> May 20 15:43:46 nas.local kernel: May 20 15:43:46 nas.local kernel: import libxml2 May 20 15:43:46 nas.local kernel: ValueError May 20 15:43:46 nas.local kernel: : May 20 15:43:46 nas.local kernel: bad marshal data (unknown type code) May 20 15:43:46 nas.local kernel: May 20 15:43:46 nas.local kernel: Traceback (most recent call last): May 20 15:43:46 nas.local kernel: File "/usr/local/www/freenasUI//notifier.py", line 42, in <module> May 20 15:43:46 nas.local kernel: May 20 15:43:46 nas.local kernel: import libxml2 May 20 15:43:46 nas.local kernel: File "/usr/local/www/freenasUI//notifier.py", line 42, in <module> May 20 15:43:46 nas.local kernel: File "/usr/local/www/freenasUI//notifier.py", line 42, in <module> May 20 15:43:46 nas.local kernel: May 20 15:43:46 nas.local kernel: import libxml2 May 20 15:43:46 nas.local root: /etc/rc: WARNING: Dump device does not exist. Savecore not run. May 20 15:43:46 nas.local root: /etc/rc: WARNING: failed precmd routine for vmware_guestd May 20 15:43:46 nas.local kernel: /etc/rc: WARNING: Dump device does not exist. Savecore not run. May 20 15:43:46 nas.local kernel: /etc/rc: WARNING: failed precmd routine for vmware_guestd May 20 15:43:46 nas.local ntpd[1762]: ntpd 4.2.4p5-a (1) May 20 15:43:46 nas.local kernel: Updating motd: May 20 15:43:46 nas.local kernel: . May 20 15:43:46 nas.local kernel: Starting ntpd. May 20 15:43:46 nas.local ntpd[1763]: precision = 1.676 usec May 20 15:43:46 nas.local ntpd[1763]: Listening on interface #0 wildcard, 0.0.0.0#123 Disabled May 20 15:43:46 nas.local ntpd[1763]: Listening on interface #1 wildcard, ::#123 Disabled May 20 15:43:46 nas.local ntpd[1763]: Listening on interface #2 nfe0, 10.113.74.4#123 Enabled May 20 15:43:46 nas.local ntpd[1763]: Listening on interface #3 lo0, fe80::1#123 Enabled May 20 15:43:46 nas.local ntpd[1763]: Listening on interface #4 lo0, ::1#123 Enabled May 20 15:43:46 nas.local ntpd[1763]: Listening on interface #5 lo0, 127.0.0.1#123 Enabled May 20 15:43:46 nas.local ntpd[1763]: Listening on routing socket on fd #26 for interface updates May 20 15:43:46 nas.local ntpd[1763]: kernel time sync status 2040 May 20 15:43:46 nas.local kernel: 16+0 records in May 20 15:43:46 nas.local kernel: 16+0 records out May 20 15:43:46 nas.local kernel: 16 bytes transferred in 0.000047 secs (340654 bytes/sec) May 20 15:43:46 nas.local kernel: Generating a 1024 bit RSA private key May 20 15:43:46 nas.local kernel: . May 20 15:43:46 nas.local last message repeated 7 times May 20 15:43:46 nas.local kernel: + May 20 15:43:46 nas.local last message repeated 5 times May 20 15:43:46 nas.local kernel: May 20 15:43:46 nas.local kernel: . May 20 15:43:46 nas.local last message repeated 5 times May 20 15:43:46 nas.local kernel: + May 20 15:43:46 nas.local last message repeated 5 times May 20 15:43:46 nas.local kernel: May 20 15:43:46 nas.local kernel: writing new private key to '/etc/ssl/freenas/CA/private/cakey.key' May 20 15:43:46 nas.local kernel: ----- May 20 15:43:46 nas.local kernel: writing RSA key May 20 15:43:48 nas.local kernel: Removing stale Samba tdb files: May 20 15:43:48 nas.local kernel: . May 20 15:43:48 nas.local kernel: done May 20 15:43:48 nas.local kernel: Starting nmbd. May 20 15:43:48 nas.local kernel: Starting smbd. May 20 15:43:48 nas.local kernel: Starting smartd. May 20 15:43:54 nas.local ntpd[1763]: synchronized to 198.55.111.50, stratum 2 May 20 15:43:54 nas.local ntpd[1763]: time reset -0.272198 s May 20 15:43:59 nas.local kernel: Traceback (most recent call last): May 20 15:43:59 nas.local kernel: File "/usr/local/www/freenasUI/manage.py", line 42, in <module> May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: execute_from_command_line(sys.argv) May 20 15:43:59 nas.local kernel: File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 443, in execute_from_command_line May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: utility.execute() May 20 15:43:59 nas.local kernel: File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 382, in execute May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: self.fetch_command(subcommand).run_from_argv(self.argv) May 20 15:43:59 nas.local kernel: File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 196, in run_from_argv May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: self.execute(*args, **options.__dict__) May 20 15:43:59 nas.local kernel: File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 231, in execute May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: self.validate() May 20 15:43:59 nas.local kernel: File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 266, in validate May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: num_errors = get_validation_errors(s, app) May 20 15:43:59 nas.local kernel: File "/usr/local/lib/python2.7/site-packages/django/core/management/validation.py", line 30, in get_validation_errors May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: for (app_name, error) in get_app_errors().items(): May 20 15:43:59 nas.local kernel: File "/usr/local/lib/python2.7/site-packages/django/db/models/loading.py", line 158, in get_app_errors May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: self._populate() May 20 15:43:59 nas.local kernel: File "/usr/local/lib/python2.7/site-packages/django/db/models/loading.py", line 64, in _populate May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: self.load_app(app_name, True) May 20 15:43:59 nas.local kernel: File "/usr/local/lib/python2.7/site-packages/django/db/models/loading.py", line 88, in load_app May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: models = import_module('.models', app_name) May 20 15:43:59 nas.local kernel: File "/usr/local/lib/python2.7/site-packages/django/utils/importlib.py", line 35, in import_module May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: __import__(name) May 20 15:43:59 nas.local kernel: File "/usr/local/www/freenasUI/../freenasUI/account/models.py", line 31, in <module> May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: from freenasUI..notifier import notifier May 20 15:43:59 nas.local kernel: File "/usr/local/www/freenasUI/../freenasUI//notifier.py", line 42, in <module> May 20 15:43:59 nas.local kernel: May 20 15:43:59 nas.local kernel: import libxml2 May 20 15:43:59 nas.local kernel: ValueError May 20 15:43:59 nas.local kernel: : May 20 15:43:59 nas.local kernel: bad marshal data (unknown type code) May 20 15:43:59 nas.local kernel: May 20 15:44:00 nas.local kernel: Starting django. May 20 15:44:05 nas.local kernel: Waiting for http... May 20 15:44:10 nas.local kernel: Failed.
