I used "warden export <jail> to export a jail from a FreeNAS box, which was successful. I then ran "warden import <jail> to import the jail to a new FreeNAS box. When I attempt to set the IP on the imported jail, I receive the following;
Request Method:POST
Request URL:http://10.0.0.17/jails/edit/1
Software Version:FreeNAS-9.2.1.9-RELEASE-x64 (2bbba09)
Exception Type:warden_exception
Exception Value:
ERROR: No such jail!
Exception Location:/usr/local/www/freenasUI/../freenasUI/common/warden.py in run, line 447
Server time:Sun, 7 Dec 2014 17:34:17 -0800
Traceback
Environment: Software Version: FreeNAS-9.2.1.9-RELEASE-x64 (2bbba09) Request Method: POST Request URL: http://10.0.0.17/jails/edit/1 Traceback: File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response 107. response = middleware_method(request, callback, callback_args, callback_kwargs) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view 158. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 22. return view_func(request, *args, **kwargs) File "/usr/local/www/freenasUI/../freenasUI/jails/views.py" in jail_edit 93. form.save() File "/usr/local/www/freenasUI/../freenasUI/jails/forms.py" in save 732. Warden().set(**args) File "/usr/local/www/freenasUI/../freenasUI/common/warden.py" in set 1069. return self.__call(warden_set(flags, **kwargs)) File "/usr/local/www/freenasUI/../freenasUI/common/warden.py" in __call 1021. tmp = obj.run() File "/usr/local/www/freenasUI/../freenasUI/common/warden.py" in run 447. raise warden_exception(msg) Exception Type: warden_exception at /jails/edit/1 Exception Value: ERROR: No such jail!
Request information
GET
No GET data
POST
VariableValue
jail_flagsu'allow.raw_sockets=true'
jail_ipv6_prefixu''
jail_ipv6u''
jail_ipv4u'10.0.0.18'
jail_hostu'Syncrify'
jail_alias_bridge_ipv4u''
jail_alias_bridge_ipv6u''
__form_idu'form_JailsEditForm'
__all__u''
jail_alias_ipv6u''
jail_alias_ipv4u''
jail_ipv4_netmasku'24'
FILES
No FILES data
COOKIES
VariableValue
csrftoken'JwUwxwW5LgW2zxPTxQU5I0kIUWAnDYpr'
fntreeSaveStateCookie'root%2Croot%2F142%2Croot%2F142%2F148%2Croot%2F142%2F148%2F150%2Croot%2F147%2Croot%2F147%2F153%2Croot%2F147%2F153%2F155%2Croot%2F110%2Croot%2F155%2Croot%2F155%2F166%2Croot%2F155%2F161%2Croot%2F155%2F161%2F163%2Croot%2F155%2F165%2Croot%2F150%2Croot%2F150%2F156%2Croot%2F150%2F156%2F158'
sessionid'xjvv22adyox328wqnchw7wla8lxjfhr5'
META
VariableValue
CSRF_COOKIEu'JwUwxwW5LgW2zxPTxQU5I0kIUWAnDYpr'
wsgi.errors<flup.server.fcgi_base.TeeOutputStream object at 0x810880110>
HTTP_HOST'10.0.0.17'
HTTP_X_REQUESTED_WITH'XMLHttpRequest'
SERVER_ADDR'10.0.0.17'
HTTP_REFERER'http://10.0.0.17/'
SERVER_PORT'80'
HTTP_ACCEPT_LANGUAGE'en-US'
HTTP_ACCEPT'*/*'
HTTP_COOKIE'csrftoken=JwUwxwW5LgW2zxPTxQU5I0kIUWAnDYpr; sessionid=xjvv22adyox328wqnchw7wla8lxjfhr5; fntreeSaveStateCookie=root%2Croot%2F142%2Croot%2F142%2F148%2Croot%2F142%2F148%2F150%2Croot%2F147%2Croot%2F147%2F153%2Croot%2F147%2F153%2F155%2Croot%2F110%2Croot%2F155%2Croot%2F155%2F166%2Croot%2F155%2F161%2Croot%2F155%2F161%2F163%2Croot%2F155%2F165%2Croot%2F150%2Croot%2F150%2F156%2Croot%2F150%2F156%2F158'
wsgi.version(1, 0)
SERVER_SOFTWARE'nginx/1.4.4'
HTTP_X_CSRFTOKEN'JwUwxwW5LgW2zxPTxQU5I0kIUWAnDYpr'
HTTP_DNT'1'
QUERY_STRING''
REMOTE_ADDR'10.0.0.202'
wsgi.multithreadTrue
SCRIPT_NAMEu''
wsgi.input<flup.server.fcgi_base.InputStream object at 0x80c298050>
HTTP_ACCEPT_ENCODING'gzip, deflate'
HTTP_CONTENT_LENGTH'244'
GATEWAY_INTERFACE'CGI/1.1'
HTTP_USER_AGENT'Mozilla/5.0 (Windows NT 6.3; WOW64; Trident/7.0; Touch; rv:11.0) like Gecko'
PATH_INFOu'/jails/edit/1'
REDIRECT_STATUS'200'
REMOTE_PORT'50807'
wsgi.url_scheme'http'
SERVER_NAME'localhost'
SERVER_PROTOCOL'HTTP/1.1'
wsgi.run_onceFalse
DOCUMENT_ROOT'/usr/local/etc/nginx/html'
CONTENT_TYPE'application/x-www-form-urlencoded'
CONTENT_LENGTH'244'
HTTP_CONNECTION'Keep-Alive'
REQUEST_URI'/jails/edit/1'
DOCUMENT_URI'/jails/edit/1'
HTTP_CACHE_CONTROL'no-cache'
HTTP_CONTENT_TYPE'application/x-www-form-urlencoded'
REQUEST_METHOD'POST'
wsgi.multiprocessFalse
Request Method:POST
Exception Value:
Traceback
Request information
GET
No GET data
POST
VariableValue
jail_ipv6_prefixu''
jail_ipv6u''
__all__u''
jail_alias_ipv6u''
jail_alias_ipv4u''
FILES
No FILES data
COOKIES
VariableValue
META
VariableValue
SERVER_PORT'80'
HTTP_ACCEPT'*/*'
wsgi.version(1, 0)
HTTP_DNT'1'
QUERY_STRING''
SCRIPT_NAMEu''
REMOTE_PORT'50807'
wsgi.run_onceFalse
CONTENT_LENGTH'244'
