I have 2x2.5" (30GB & 60GB) drives sourced from old laptops which I feel are perfect for a pfSense install. Unfortunately, they are from really old Dell laptops and so they are IDE drives.
I found these adapters but all are from China and I am not sure how much to trust these adapters. On the other hand, pfSense is really easy to re-install on a new HDD/SSD and put your saved config back in.
Secondly, I will also need a PCIE extender card/ribbon cable so that I can put my mini-ITX (AsRock J3355B) board into my existing 1U Supermicro chassis. Again, I found a few Chinese ones but I am not sure if they will be reliable enough for my Intel i340-T4 card.
Does anyone have any experience with these ribbon cables? I already have a Supermicro Riser card but I cannot find a PCB board extender that doesn't have 90Degree angle. That's why I thought the ribbon cables might work but I am not too sure of the quality.
Thanks for your advice.
- https://www.newegg.com/Product/Prod..._sata_adapter_thzy-_-9SIABR04YT7283-_-Product
- https://www.newegg.com/Product/Prod..._sata_adapter_thzy-_-9SIABR04YT9070-_-Product
- https://www.newegg.com/Product/Prod...de_to_sata_adapter-_-2BH-000B-00002-_-Product
- https://www.newegg.com/Product/Prod...re=ide_to_sata_adapter-_-12-200-196-_-Product
- https://www.newegg.com/Product/Product.aspx?Item=9SIA6705VF3925
- https://www.newegg.com/Product/Prod...cie_extender_cable-_-9SIADTU5Z51810-_-Product
- https://www.newegg.com/Product/Prod...cie_extender_cable-_-9SIA6705VF3925-_-Product
- https://www.newegg.com/Product/Prod...cie_extender_cable-_-9SIA6706X93678-_-Product
- https://www.newegg.com/Product/Prod...cie_extender_cable-_-9SIABR04N70539-_-Product
- https://www.newegg.com/Product/Prod...cie_extender_cable-_-9SIABR04YT6973-_-Product
