I think my boot SSD is dying
Yorick
WTF. This ain't right. It's an SSD! It's not allowed to die! I'll run some smaaahts and see what they say. A power-cycle got it back, for now.
For giggles, did you check the power and data cable connections? Could be a wonky connection due to heat, gravity, vibration... (Or bad planet alignment, stray neutrino, forgot to pray to the silicon gods, etc. :cool: )
Yorick
Did you check the power and data cable connections?
Not yet. It's an M.2, so, I really don't expect that anything can jiggle loose. And, sure, why not, I can remove it, and stick it back in, just because.
Yorick
Smart isn't being super-helpful. "Error info log entries" but those could be literally anything; no spares used; manufacturer drive life at 1% used, 99% remaining. It's cool and didn't log heat issues at any point.
Used https://media.kingston.com/support/downloads/MKP_521.6_SMART-DCP1000_attribute.pdf to interpret these smart data fields.
freenas# smartctl -a /dev/nvme0
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.1-STABLE amd64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Model Number:                       Patriot Scorch M2
Serial Number:                      0xdeadbeef-don't-register-my-drive-bruh
Firmware Version:                   E8FM11.5
PCI Vendor/Subsystem ID:            0x1987
IEEE OUI Identifier:                0x6479a7
Total NVM Capacity:                 128,035,676,160 [128 GB]
Unallocated NVM Capacity:           0
Controller ID:                      0
Number of Namespaces:               1
Namespace 1 Size/Capacity:          128,035,676,160 [128 GB]
Namespace 1 Formatted LBA Size:     512
Namespace 1 IEEE EUI-64:            6479a7 115327fde8
Local Time is:                      Tue Jul 14 09:25:08 2020 EDT
Firmware Updates (0x02):            1 Slot
Optional Admin Commands (0x0017):   Security Format Frmw_DL Self_Test
Optional NVM Commands (0x001e):     Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat
Maximum Data Transfer Size:         512 Pages
Warning  Comp. Temp. Threshold:     84 Celsius
Critical Comp. Temp. Threshold:     88 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
0 +     3.00W       -        -    0  0  0  0        0       0
1 +     2.00W       -        -    1  1  1  1        0       0
2 +     2.00W       -        -    2  2  2  2        0       0
3 -   0.1000W       -        -    3  3  3  3     1000    1000
4 -   0.0050W       -        -    4  4  4  4   400000   90000
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
0 +     512       0         1
1 -    4096       0         0
=== START OF SMART DATA SECTION ===
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        22 Celsius
Available Spare:                    100%
Available Spare Threshold:          50%
Percentage Used:                    1%
Data Units Read:                    748,279 [383 GB]
Data Units Written:                 567,665 [290 GB]
Host Read Commands:                 22,466,116
Host Write Commands:                15,176,756
Controller Busy Time:               331
Power Cycles:                       41
Power On Hours:                     12,816
Unsafe Shutdowns:                   28
Media and Data Integrity Errors:    0
Error Information Log Entries:      462
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Temperature Sensor 2:               22 Celsius
Error Information (NVMe Log 0x01, max 16 entries)
Num   ErrCount  SQId   CmdId  Status  PELoc          LBA  NSID    VS
  0        462     0  0x0005  0x0005      -   4009754624     0     -
  1        461     0  0x0004  0x0005      -   4009755904     0     -
  2        460     0  0x0005  0x0005      -   4009754624     0     -
  3        459     0  0x0004  0x0005      -   4009755904     0     -
  4        458     0  0x0005  0x0005      -   4009754624     0     -
  5        457     0  0x0004  0x0005      -   4009755904     0     -
  6        456     0  0x0005  0x0005      -   4009754624     0     -
  7        455     0  0x0004  0x0005      -   4009755904     0     -
  8        454     0  0x0005  0x0005      -   4009754624     0     -
  9        453     0  0x0004  0x0005      -   4009755904     0     -
10        452     0  0x0005  0x0005      -   4009754624     0     -
11        451     0  0x0004  0x0005      -   4009755904     0     -
12        450     0  0x0005  0x0005      -   4009754624     0     -
13        449     0  0x0004  0x0005      -   4009755904     0     -
14        448     0  0x0005  0x0005      -   4009754624     0     -
15        447     0  0x0004  0x0005      -   4009755904     0     -
Yorick
zpool status - scrub doesn't find issues either. Hmm. I may just watch it for now and see. I do wish I knew what to make of my increasing error count on those two LBAs.
  pool: freenas-boot
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
        still be used, but some features are unavailable.
        the features. See zpool-features(5) for details.
  scan: scrub repaired 0B in 0 days 00:00:07 with 0 errors on Wed Jul  8 03:45:07 2020
        NAME          STATE     READ WRITE CKSUM
        freenas-boot  ONLINE       0     0     0
          nvd0p2      ONLINE       0     0     0
errors: No known data errors
Yorick
Patriot didn't even want to troubleshoot and just issued an RMA. I guess that answers that: It's going bad.
I'm going for an Optane 16GB with the theory that I can boot from it. Wish me success :).
Yorick
I sacrificed a SAS-to-SAS breakout cable, and the computer gods were kind. Intel Optane 16GB works just fine as a boot drive.
@Yorick - You did complete this by sacrificing something to the computer gods, right? If not, you need to do this quickly! :tongue:
