I ran pkg2ng and broke something
hlt32
I'm running FreeNAS 11.2-rc2.
I was trying to install vim and openvpn in a jail, but the packages were not found in the repo.
I followed some instructions I found to run pkg2ng, and received the following: https://pastebin.com/whdzNrf2
Now I can't update, upgrade, or install any packages - can someone please explain what I did wrong and how to start fixing this?
Thanks
hlt32
I think I fixed it.
/usr/local/etc/pkg/repos/local.conf -> enabled: no
/usr/local/etc/pkg/repos/FreeBSD.conf -> enabled: yes
then pkg update && pkg upgrade
8-bit Yoda
root@freenas[/]# pkg search vim
pkg: Repository local missing. 'pkg update' required
pkg: Repository local load error: access repo file(/var/db/pkg/repo-local.sqlite) failed: No such file or directory
pkg: file:///usr/ports/packages/meta.txz: No such file or directory
pkg: file:///usr/ports/packages/packagesite.txz: No such file or directory
root@freenas[/]# pkg update
Updating local repository catalogue...
repository local has no meta file, using default settings
Unable to update repository local
Error updating repositories!
What happened to the "in a jail" part? It looks like you're trying to install packages on the FreeNAS host...
