I can not reach any host in the network
g3dba
Hi. I'm new with freenas, I installed frennas corral and I was working on it without issues, but after I poweroff the server for maintenance on the electricity network, I lost the connectivity to the network. Freenas was working fine, but after I started again the server, It was not possible to reach the gateway and all the hosts on my network. I just have one switch, and all the other server are connected to the same switch, These are the parameters of my network, can you take a look and see if Ihave something wrong on the configuration.
Thanks in advance.
g3dba
Wow, thanks for you quick response, I think is better to move to 9.1 version if Iwant to have it on a production environment.
Jailer
Not strong, but bad
The naming convention can be a bit confusing. As @HeavyWeaponsGuy stated 9.10 is the current stable release.
