HTPC Manager - DISK
wreuel
Hi everyone,
I just came back to the FreeNAS system after a while, well I have done a lot of configuration this week, but I got stuck with some configuration in the HTPC Manager.
1. How can I put the HTPC Manager to check the others disks? I have 3 Disk in my system, but the HTPC is just monitoring where it is installed. The others are mounted in /mnt/MOVIES and /mnt/TVSHOWS, how can I put the HTPC Manager to see them?
2. I have two Transmission running in my system, one in the 192.168.1.10x:9091 and other in 192.168.1.10x:9091 one only to MOVIES and another only to TVSHOWS, but I haven't found anything in the HTPC Manager how to config two Transmission there! Anyone with some idea?
Thank you for your help.
Joshua Parker Ruehlig
htpc-manager can only view disk/directories that are mounted into the jail. so maybe that's why you can't see them?
as for other stuff you might have more luck asking on the htpc-manager github.
any reason you need separate transmission instances for different file types? did you know that programs that have explicit transmission support (not just black hole torrent support) like couchpotato and sickrage can specify a directory for transmission to download to.
wreuel
Well, about the drivers, I have mounted the other two drivers into the htpc manager jail already, but is not showing up! Is that what you mean?
Well, the only reason I separated was in the beginning I used to have the sickrage and the sickbeard together, but I can see now that I will not need this anymore.
do the locations show with 'ls -l /path/to/folder'
sickbeard doesn't actually have transmission api support like sickrage does.
wreuel
Where should I put this code? It is in one of the spaces in the Setting/System Info?
no, in the jail htpc-manager
is installed to, to verify the path you want to monitor actually exists in the jail
wreuel
Yeah, I checked they exist, they are FILMES and SERIADOS.
I would ask somewhere specific for htpc-manager help then. looks good to me.
wreuel
no prob. good luck
marcevan
Hey I have Movies, TV, and Music mounted in storage for HTPC Manager so in the system info mountpoints I put in /mnt/TV /mnt/Movies /mnt/Music but it never shows.
