marcevan
- Dec 15, 2013
I gave HTPC manager a shot this AM thinking would be nice to see a dashboard for my plugins.
* Sickrage: put in the URL and port, API key and tested it, went green and enabled it: works
* Transmission: put in the URL and port and tested it, went green and enabled it: works
Now for:
* Plex: put in the URL and port, API key, username and password and wont' test ok; removed username and password and still won't test ok. Using same username and password Sickrage uses to integrate with Plex which works fine, btw. So a bit stymied why Plex cannot be reached while Sickrage and Transmission can.
Note: the log entry from HTPC-Manager shows:
modules.plex ERROR Failed to get authtoken from plex 401 Client Error: Unauthorized
--> Plex says to use this format:
http://192.168.1.12:32400/library/metadata/147?X-Plex-Token=YOURTOKENVALUEHERE
but in HTPC-Manager, there's a URL and a PORT so no way to add a path including the Token.
* Headphones: put in the URL and port and API key and tested: nope.
Anything special I should be doing for Plex and Headphones to work in HTPC Manager?
Now for:
