HPE ML110 Gen10 and HDD temp
osalj
I have an HPE ML110 Gen10 server running TrueNAS SCALE 22.12.4
I have disks installed:
OS: 2x KINGSTON_SV300S37A60G - ZFS mirror
STORAGE 1: 4x Seagate ST4000NM002A-2HZ101 - raid z1
STORAGE 2: 2x Seagate ST3000VN007-2AH16M - mirror ZFS
All drives have S.M.A.R.T. enabled. and HDD Standby is Always on.
My disk temperatures were always displayed correctly.
I don't know why they stopped displaying correctly.
The current temperature is approximately 68,719,476,771 °C
Something's obviously wrong.
Smartctl shows disk temperatures correctly.
194 Temperature_Celsius -O---K 030 053 000 - 30 (0 16 0 0 0)
The drives are connected directly to the motherboard and the drive controller is set to SATA AHCI.
The only thing that changed was that I connected two SSD drives to perform some tests.
I didn't change anything else in the server.
do you have any ideas?
sfatula
There is another thread about this, it appears to be a bug in the latest Scale. It will be fixed in Cobia.
sfatula
How is it possible that everything was fine three days ago?
Latest update changed it, as you can see from reading that thread, others have the same issue including me.
