HP Probook 400 G4 mini Desktop
Hello y'all,
I am new to Truenas/Freenas :smile:
I want to install it on a HP Probook 400 G4. I formated a usb-stick (fat32) and flashed TrueNAS-12.0-U3 onto it with balenaEtcher. On the probook (bios) i disabled legacy support and secure boot. The stick will boot and i am able to choose: install. After that i get the following messages (and the machine freezes)
(below is taken over from a bad screenshot, sorry, not 100% accurate)
can't find /etc/hostid
can't find openzfs
can't find /boot/entropy
Start @ 0xffffffff80370000 ...
EFI framebuffer information:
addr,size 0xb0000000, 0x7e9000
dimensions 1920 x 1080
stride 19290
masks 0x00ff0000, 0x0000ff00, 0x000000ff, 0xff000000
Any ideas?
Thnx!
Perhaps i should enable legacy support.. (will do that next)
[update]
Didn't help. I also updated the bios and did a rollback of the bios. None helped.
[update]
I am able to install ubuntu/OMV on this pc using a usb-stick so....
[update]
Tried again using RUFUS, MBR and disable Uefi in the Bios...
