Strange Rover
- Sep 24, 2020
Hi, this is my first post on here so please be gentle...
I've just set up a build on an HP DL180g6 which has the P410 raid controller in it but looking online and using the search feature on here I'm getting conflicting information about if it is safe to use the P410 - some are saying it is safe to use and some say it is unsafe.
The DL180 g6 is a 2u chassis and has 14 drives, 2x 120gb with the boot pool mirrored, I then have 12 WD Red 6TB drives split into 3 pools, 1 pool of 6 drives, 1 of 4 drives, both on raidz2 and a mirrored pair for jails, etc. The system has twin Intel Xeon E5620 @ 2.40GHz and 32GB of ram.
If the P410 is unsafe to use what would you recommend to use instead and will 32GB of ram do or do I really need more?
