During my research I found that HP servers can become very noisy when used in with TRUENAS. The reason seems to be that their fans gets stuck at 43% all the time.
Apparently, HP uses their onboard disk controller to obtain the Disk temperatures and use that info to control the fans. But, for some reason, they only do this when their onboard controller is set to “HP RAID” and they use a daemon to monitor the HD temps when the controller is set to “AHCI”.
The daemon is called “Agentless Management Service” (AMS) and, when it is installed, the server lowers the fan speeds to 6% which makes it so much quieter.
The problem i found is that AMS is only available for windows and linux systems, not freebsd. So, i ask, how do people with HP microservers in this forum handle this situation?
Do they just accept the noise as a fact of life? or do they try to install AMS in a linux VM?; if the second, can AMS access the disk data from a VM?
Any help would be appreciated.
