HP AD194-60001 PCI-X dual port fiber / ethernet card
steve001
Morning guys ,
trying to find out is this card supported by freenas ? i have 9.1.1
still trying to get my head round where stuff is, looked on hardware support but had loads of tabs open and search didn't find anything.
Steve
:confused:
steve001
here are pics will have a look at the link tonight , hope that it will work :) with freenas
TheSmoker
That's good. Put FreeNAS on a usb stick, boot it up and see if it will recognize it. It will, most probably as em(x) where x will be a number starting with 0.
Let us know how that went.
Sent from my iPad using Tapatalk HD
steve001
not going to get chance to have a good go with it till weekend will let you know how i get on , or maybe back on here asking for help
Regards
Steve
steve001
I am back . . :( put card in and boot up freenas and it goes through usual stuff then I get the following errors and it fills the screen
isp 0 : mailbox cmd (0x400) with no waiters
isp 1 : mailbox cmd (0x400) with no waiters
any ideas
Steve
jgreco
Resident Grinch
That's a dual port fiber channel, dual port ethernet, I think. Go into the card's firmware configuration and make sure that every last bit of fiber channel configuration is bludgeoned out, bludgeoned off, and/or disabled so that it isn't trying to attach to something.
steve001
not as yet , there is nothing connected to the machine its on its own ,was just trying to see if it boots ok
do i need to hook up via fiber interface ?
steve
jgreco
Resident Grinch
Well, it seems likely that it is unhappy that there's no array or SAN attached.
steve001
Noticed today during booting my system i get the message "PCI CONFIGURATION ERROR"
i can't enter the BIOS of the card either. When i press Ctrl-Q nothing happens. A bit of googling i found out that the nvram could be corupted and needs to reset. QLOGIC won't give the needed information (and files), because the card is an OEM-Card for HP
The BIOS lists the card as a QLOGIC QLA2462
So i want to ask if there is anybody on here who can tell me how to reset the nvram ? and maybe a BIOS that is not OEM
Steve :(
Not to burst your bubble, but your question is beyond the scope of this forum. I wouldn't expect a response. You should probably Google around and see if you can find it posted elsewhere.
