flashdrive
- Apr 2, 2021
as per GUI the pool is degraded
theory:
1) HDDs are not capable for long time run NAS
2) HDD spindown is affecting this negativly
3) HDD vibrations are too much for the system to stay always online
Howto:
todo's:
www.truenas.com
references to read:
www.truenas.com
zpool & glabel status
www.truenas.com
theory:
Howto:
- Check all physical connections (power and data)
- unplug and replug
- check BIOS / EFI if all drives are listed
- check Boot order
- resilver pool
- disable cron job for auto shutdown / enable after resilver finished
todo's:
no active internet connection - how to be notified in case of errors?
Hello, I have a build without an active internet connection (on purpose). What options do I have to get a messge in case of system errors, i.e. pool degradation? I can think of: periodical manuel login into the web interface / TrueNAS dashboard SNMP ...
references to read:
Hard Drive Burn-in Testing
@jgreco did a nice system build/test/burn-in guide here, but I (and many others) found the details a bit lacking in the hard drive section. He mentions S.M.A.R.T. tests, but doesn't go over how to run them, or how to view the results, etc. and...
DEGRADED zpool with one FAULTED device
Greetings, My server configuration Type: SuperMicro SYS-6029U-E1CR25M Processor: Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz Memory: 12 x 32GB Samsung M393A4K40DB2-CVF Storage: 2 x 256GB NVMe SSD, INTEL SSDPEKKA256GB 12 x 16TB HDD, Seagate ST16000NM001G-2KK103 TrueNAS-12.0-U3.1 - Boot: 1 x 2-way...
