I want to use a Docker container to convert an mkv video to an HLS "video". This is my command for it:
when i run this command everything is created correctly, with VLC i can use the m3u8 file only Video.js says "The media could not be loaded, either because the server or network failed or because the format is not supported". I have also set the audio codec and video codec to AAC and 264 for testing but it didn't work any better. Ich nutze Video.js und wenn ich auf einem anderen Rechner wo ich kein docker nutzen muss geht m3u8 im web aber nicht bei vlc mit diesem befehl.
you do not need to take into account the directories that I have changed.
			docker run --rm \
-v /mnt:/config \
linuxserver/ffmpeg \
-i "/config/test.mkv" \
-c:v copy \
-c:a copy \
-sn \
-f hls \
-hls_list_size 0 \
/config/hls/output.m3u8
ffmpeg -i input.mkv -c:v h264 -master_pl_name master.m3u8 -hls_time 10 -hls_list_size 0 -f hls -map 0 -c:a aac -b:a 128k -strict -2 -vf "subtitles=input.mkv" -map a -map v -map s -var_stream_map "a:0,v:0,s:0 a:1,v:1 s:1" test/stream_%v.m3u8
