how to upgrade plugins for 9x
DM1977
Hi All,
I have upgraded (guid upgrade) from freenas 8.3.2 to 9.1.1. i had one jail running with 5 plugins in it sabnzbd, sickbeard (from http://forums.freenas.org/threads/sabnzbd-sickbeard-couchpotato-pbis.6221/) etc. after the upgrade I did the jail migration (http://doc.freenas.org/index.php/Migrating_an_8.x_Jail) with success.
è Due to binary incompatibility between FreeBSD 8.x and 9.x applications, you will need to reinstall your applications after the jail is migrated. Existing FreeNAS® plugins will be displayed under Services Plugins. However, they will be in the 8.x format and will not work until they are upgraded to 9.x.
Question:
The jail is there now and I can start it but how can I easily upgrade the plugins to work with the FreeBSD 9? And can anyone tell me where I can download the pbi for sabnzbd and sickbeard so that I can install them manually in my single jail? I do not want to create several jails per plugin.
In other words i do not want to loose all my settings on those installed applications.
Thanks in advance for your help!
