How to Upgrade from 9.2.1.3 to 9.2.1.7
SandmanZA
Hi all
How do I upgrade to the latest version - I am on 9.2.1.3.
Do I just download the upgrade Gui_Upgrade.txz file and apply or are there any intermediate steps ?
Yatti420
Yep.. Check the sha256 hash is correct and then upload it.. Ofcourse backup your current config first..
Step by step instructions for upgrading are in our documentation...
soundiego
I upgraded to 9.2.1.7 and could not log in again in the WebGI. I selected option 7 in the server's menu and have tried every combination I could imagine: admin/freeness (user/password) was my fist attempt and didn't work. Since then I've tried all combinations between old user, admin and old and default passwords with no success.
Any clue?
soundiego
It worked! How can I thank you?
But I don't understand what the option 7 "Reset Web GUI login credentials" does.
I've never used that option, so I can't say for sure. The manual says it's supposed to clear out the root password, so the next time you go to the WebGUI, you need to set it. Once you set the password, you'd log in with root and that password. If it didn't do that, you should probably file a bug report.
robles
Yes, I used it 2 weeks ago. You use the console to reset the WebGUI password and the next time you access it, it asks you for a new one: the same setup you do when configuring a new FreeNAS instance.
ngacleetus
Every time I try to upload from 9.1.3 it says "An error has occurred". Not sure what the issue is.
diedrichg
If you are using Firefox, try Chrome. If you are using Chrome, try Firefox.
