I need some help with network settings. Basically i have two Network connections going into my FreeNAS box and i need to send all traffic to a specific IP over one of the connections, and the rest over the other connection. I have setup the static route fine on the Host, the problem is that inside the Jail i cant seem to access the second connection at all.
1st Connection:
Gateway: 192.168.0.1
FreeNAS IP: 192.168.0.5
NetMask: 255.255.255.0
2nd Router:
Gateway: 192.168.1.1
FreeNAS IP: 192.168.1.2
Jail Network settings:
IP: 192.168.0.6
I have configured 192.168.0.1 to be the default route from the web ui.
Inside the host i can ping 192.168.0.1 and 192.168.1.1
Inside the jail i can ping 192.168.0.1 but not 192.168.1.1
i have full control of the routers on both connections. Can somebody please tell me how i should configure my network settings to get this to work.
1st Connection:
2nd Router:
IP: 192.168.0.6
