SOLVED How to remove ACL from Pool Dataset
cephyr
Hi guys,
I want to remove the ACL on my top dataset but I cant find a way.
On the sub dataset's I can strip the ACL with the ACL editor but this is not possible with the top one, there I can only view the permissions
Compared to a freshly created pool it uses NFS4 ACL - this is a pool imported from an old CORE System
freshly created under scale:
Does anyone know a way how to get rid of the ACL in the top dataset?
I've already tried with setfacl but I think I would need to use nfs4xdr_setfacl but I dont know the right command.
Thanks in advance.
cephyr
Update:
I found the solution:
three dots -> edit options -> Advanced Options
ACL Type from NFS to Off
anodos
Sambassador
Why were you wanting to remove ACL? Some changes merged into Linux's zfs_acl.c a couple of years back changed definition of trivial ACL which impacts how ACLs from Core are represented on SCALE. Generally speaking, functional impact should be non-existent.
cephyr
I was fiddeling with the ACL's and the freshly created pool did not had this "ACL" marker.
So I thought it could solve the problems that I had. But it turns out it has to do with the ACL's not getting applied recursively for me..
