I want to move this, but can't find any way for deleting the existing dataset as I get a "cannot unmount mnt/APE_Pool/Adrian/syslog: device busy" message.
Try to run this from command line (either console of SSH, do not use the web GUI shell):
[panel]service syslogd stop
service nginx stop
zfs destroy APE_Pool/Adrian/syslog[/panel]
And then reboot -- you can just type "reboot" in the shell.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
