SOLVED How to monitor data copy upload to cloud?
ericg75
My TrueNAS Core setup:
TRUENAS-13.0-U5.1
MB: Asus Z390-A
CPU: intel i7
RAM: 16GB
HDD's: ada0 Crucial 128gb BOOT DEVICE
ada1 WDC WD60EFAX 6TB
ada2 WDC WD60PURX 6TB
HD Controler: ONBOARD
ETH0: ONBOARD
Wanting to see how/if I may monitor my Cloud Sync job so as to see what (or where) in the list of files (32GB) the job is currently. I am trying to see/monitor where my copy/push job is overall. The total size is around 32GB- and it has been running for over 3 weeks now. Every time I look at my network traffic from the TrueNAS box it is 20 to 40 Mb/sec- so I am beginning to wonder where I am with the copy function. Anyway to see a % complete?
In the list of Cloud Sync Tasks, you will see the running task with a Status of Running... that is actually a button... click it.
ericg75
Very good information! I did not realize that it was a button.
I must ask though: Is there a way to actually monitor (ie: see), in a log, at what point in the file system transfer copy process is? IE: Progress of the transfer.
If there is, I haven't yet discovered it.
I'm not convinced anything is logged by the rclone process during its run though and the status is only tracked by the task while it runs and the status at completion is the only record you get.
ericg75
Ok then. I will use the dry-run function and watch status from there.
This is completely resolved. I am searching for how to close this post- How do I close it out?
I did it for you, but it's with "Edit thread" and mark it as solved
ericg75
Very good- I see it now. Thank you much!
