Today I want to test a java program in jail.
My TrueNAS version is TrueNAS-12.0-U2.1 and jail is a Clone Jail (12.2 RELEASE).
After the creation, I use those command to install the Java Runtime Environment
After the install, the post-install note remind me to do the follow settings.
I have done a research and found an old solution.
www.truenas.com
The solution require me to mount the filesystem from Host but I am not sure if I can follow the solution directly as the Jail Manager is bhyve in TrueNAS.
Any suggestion are welcome. Thank you.
pkg update pkg install vim wget openjdk11-jre
====================================================================== This OpenJDK implementation requires fdescfs(5) mounted on /dev/fd and procfs(5) mounted on /proc. If you have not done it yet, please do the following: mount -t fdescfs fdesc /dev/fd mount -t procfs proc /proc To make it permanent, you need the following lines in /etc/fstab: fdesc /dev/fd fdescfs rw 0 0 proc /proc procfs rw 0 0 ======================================================================
Little over my head. Hoping to get Unifi Controller installed in FreeNAS.
You probably are root. If you are don't use sudo. It will not be found. I've made a fresh jail for testing and then I did this: pkg update pkg upgrade portsnap fetch update #this gives an error. Extract portsnap first portsnap extract portsnap fetch update #portsnap is up to date. cd...
