nello
- Dec 30, 2012
CrashPlan decided to upgrade my Java Runtime Environment (JRE) from 1.7 to 7.
I think that it installed the 32-bit version, based on these log entries:
How can I tell whether I have a 32- or 64-bit JRE?
If I have a 32-bit JRE, how do I upgrade it to 64-bit?
Thank you.
- nello
Java Installed. Unpacking remaining upgrade files currentDir=/usr/pbi/crashplan-amd64/share/crashplan/upgrade/1435813200470_344.1468472873812 120511 blocks Removing existing app files... Adding updated files... 32 bit version detected, using 32 bit electron.
Thank you.
- nello
