how to identify drive or change mail notification settings
denut
hello
i have a question about the mail notification system from truenas
i recive this : Disk 17672025968873941789 is REMOVED
how can i found the serial number from the drive
if the drive is no more present is there a solution
is it a solution to hve the drive serial number in place of this id in mail
thank's
If it's no longer visible in the system, you'll need to do it in reverse and eliminate all the other serial numbers you can find on the other disks, leaving you with the disk you need to check.
Patrick M. Hausen
dmesg and camcontrol devlist might help.
