boris_d
Neophyte
- Jan 19, 2017
My used HW: USB stick + Desktop PC (not the server board) with a motherboard Asus P9X79 WS (hosting i7-3930K + 16GB RAM but it doesn’t matter). The motherboard shall support UEFI version >=1.0 and be able to access USB from BIOS/EFI shell.
Step-by-step procedure:
Some additional information
Building my first FreeNAS home server I’ve taken a Delock PCIe controller 89395. Its chipset Marvell 88SE9230 provided no errors in FreeNAS 9.10, but the S.M.A.R.T. tests on the connected disks failed regularly. Swapping the HDDs between the controller and motherboard SATA demonstrated that the HDDs were healthy, pointing to the controller as a cause of problem.
Looking for a better controller I’ve learned the popular LSI 9211-8i, which is optimal for my setup as well (8xHDD). The only disadvantage of the card is the IR firmware, which shall be overwritten at home by the IT version. People out there claimed with a lot of frustration attempting to overwrite the firmware. My experience has confirmed this and after a week of try-and-error, ending in success I've thought to share my experience.
To the question why I haven’t used my server board for flashing – I’ve tried and failed. My current server is built with some exotic industrial mini-ITX. I've issued troubles and couldn't find any information in the web.
My current configuration: motherboard DFI HR100-CRM, i5-2510E 2.5GHz, 16 Gb RAM, FreeNAS 9.10 on 8 Gb CF card, 8 x 4Tb Seagate ST4000DM000 HDD.15, RAIDZ2, case Silverstone DS-380, Power Supply 450W Silverstone ST45SF-G.
The FreeNAS 9.10 runs without any problems.
The used motherboard is only temporal solution for the first experience. It will be replaced next time by: ASUS P10S-I + Xeon E3-1240 + 32 Gb ECC RAM –currently the best CPU Mark/$ on the DIY home server market. The Atom C2xxx boards (Supermicro, Asrock) are NoGo due to the known CPU bug and pure performance/$ (compare the CPU Mark and prices on the market). Secondly the passive cooled Atom boards overheat according to user experience and require active cooling as well.
Some useful sources:
Boris
- Insert the controller card in a PCIe slot. (I’ve used the slot Nr. 3. In case of troubles recognizing the card in your desktop PC try different slots.)
- Boot the PC and prepare the USB stick:
- In the USB stick create and format a FAT or FAT32 partition >= 10 MB. (I’ve created 500 MB FAT32 partition. I wouldn't recommend large partitions, who knows if the EFI shell will read every big partition.)
- Create the sub-folders for EFI boot. In the web there are two different structures: /boot/efi and /efi/boot. For time saving I’ve created both groups, it works.
- Download from Broadcom following packages: Installer_P20_for_UEFI and 9211-8i_Package_P20_IR_IT_Firmware_BIOS_for_MSDOS_Windows and extract them on your PC’s HDD.
- Copy from the downloaded packages three files to the USB stick root folder:
- from the first package the file sas2flash.efi (it is in sub-folder /sas2flash_efi_ebc_rel/);
- from the second package: 2118it.bin (it is in sub-folder /Firmware/HBA_9211_8i_IT/) and mptsas2.rom (it is in sub-folder /sasbios_rel/).
- Download from Github Tianocore the precompiled UEFI version 1 Shell: Shell_Full.efi. (Only v1 is applicable, later versions are not compatible with the flash tool and end up with the message: “InitShellApp: Application not started from Shell”.)
- Rename the Shell_Full.efi in ShellX64.efi and copy this file to following three USB stick destinations: root folder, /boot/efi/, /efi/boot/. (Again, there are different advices, for time saving it easier to use all three choices.)
- The creative part is completed, it's time for action. Restart the PC and enter the BIOS. If you use ASUS UEFI BIOS Utility in advanced mode, mouse click on the Exit (not by using keyboard “Esc”), in the next dialog select “Launch EFI Shell from filesystem device”. Other BIOS should behave similarly.
- Next you should see starting shell execution, ending with a prompt: "Shell>" (not the "2.0 Shell>"!).
- Type the command:
map –b
(+Enter) for listing of available disks. Locate which one is your USB stick. In my case it is the fs6:
"fs6 :Removable HardDisk - … USB(…)" - You can break further execution of the map command by
q
. - Switch to the located USB stick by command
fsN:
(+Enter) (N=6 – in my example = "fs6:", set N to your USB stick ID). Dir
shows the file list:
2118IT.BIN
MPTSAS2.ROM
sas2flash.efi
<DIR> BOOT
<DIR> EFI
ShellX64.efi- The action can start. During it the power shall not be brocken!
- Erase the controller flash memory:
sas2flash.efi -o -e 6
. - Write the new firmware to the flash:
sas2flash.efi -o -f 2118it.bin -b mptsas2.rom
. - After a while you'll see the success message. You can restart the PC and check if the controller BIOS reports the new “IT”-firmware.
- The card is ready to use.
Boris
