How to delete a volume invisible in GUI
profwalken
I'm stuck with something about an old volume become impossible to delete because in GUI is no more visible but from a windows computer root folder and subfolders are always on the drive.
From windows I get insufficient rights to delete so how can I force this to be really deleted?
Thanks for advices
Samuel Tai
Under Sharing->Windows Shares, delete the share that's no longer attached to a dataset. Then restart the SMB service.
If you have a pool that was removed without being removed first in the GUI, you may have what I call a zombie pool:
profwalken
Thanks for answer, but my case is not an SMB share, the old folder was from a deleted dataset used by FTP
profwalken
this is the name of the root folder dataset(invisible in TRUENAS GUI) , in which I have one subfolder from a deleted user fmcv
Do I need to try what Sretalla answer me about the zombie pool?
Samuel Tai
Yes, you do appear to have a zombie pool.
profwalken
Well as a nonexpert I tried to follow the same process in CLI and got this:
What's wrong ?
Ok, we need to see what's happening here:
zfs list | grep supprimer
profwalken
is it possible i try this command:
zfs destroy supprimer/ .mnt/Stockage/Sauvegardes/supprimer
profwalken
OK, so what we're being told here is that you have a directory (which is not a dataset) located at /mnt/Stockage/Sauvegardes/supprimer
That directory is not empty.
You need to look at what's there:
ls -l /mnt/Stockage/Sauvegardes/supprimer
And decide if it's valuable to you... delete it if not rm -r /mnt/Stockage/Sauvegardes/supprimer
profwalken
Thanks Sretalla, you've been Right on target, like always better one who knows than 10 searching:wink::tongue:
just did the deletion command and now no more "supprimer" folder :smile:
