Has anyone figured out the default I/O sync behavior for a bhyve VM created in FreeNAS 11?
I'm having a problem where the VM (Windows 10 in this case) is under reasonable disk I/O load, the entire server becomes fairly unresponsive when any disk I/O is involved.
Host config:
While the host becomes unresponsive every once in a while, the guest VM is so unresponsive I can't get VNC to show any activity, and can't get RDP to connect. I usually use RDP and it will actually terminate the session citing the host has stopped responding. :-/
And during these periods, the host is showing bhyve at 800%+ utilization, mainly with state kqread.
Host config:
- 5 disks are in a long-time RAID-Z2, no other problems with jails, SMB, etc.
- 16/32 Xeon cores/threads
- 64 GB RAM
- No host swap being used
- Windows 10 x64
- Fresh install, and updated
- 80 GB zvol for disk, on the Z2 vol mentioned above
- 12 GB RAM allocated
