How to build a PCIe bracket for a standard SSD that powers it too
Bidule0hm
Server Electronics Sorcerer
Index
Disclaimer: only you are responsible of what you're doing to your server, incorrect build can lead to fire and/or to the destruction of the SSD, MB, PSU, or any other component connected to the same system. These instructions are not for the beginner; use them at your own risks.
Bidule0hm
Reserved.
Bidule0hm
Introduction
What we want to do is a bracket that will be capable of holding the SSD in a PCIe slot and use the slot +12 V rail to power the SSD.
We will use the male connector of a cheap PCIe riser and some aluminum angle to make the bracket.
The PCIe slot only have a +12 V and a +3.3 V rail but a 2.5" SSD works with 5 V so we will use the good old LM7805 to make a +5 V rail from the +12 V rail of the PCIe slot.
Bidule0hm
Reserved.
Bidule0hm
What you'll need
  • 1x SSD
  • 1x SATA cable
  • 1x SATA power cable
  • 1x PCIe riser
  • 1x LM7805
  • 2x 22 to 100 µF (16 V minimum) electrolytic capacitors
  • At least 100 mm of aluminum angle
  • A few small bolts, nuts, washers, ...
SSD and SATA cable
Well, I assume I don't have to give any details on that... :D
SATA power cable
Any reasonable quality SATA power connector with 10-15 cm of cable is perfect. Personally I used a molex to SATA adapter and just cut the molex connector.
PCIe riser
It's probably the most difficult part to find for this project but ebay is magic... What you want is this (it's only the male connector of the riser):
It needs to have holes (or you'll have to use some epoxy in place of the bolts...), usually you can see through the tape if there's holes or not in the PCB. For example:
It can be found for less than 2 dollars. Personally I've chosen this one: http://www.ebay.fr/itm/301747622928?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
LM7805
It's just a 5 V regulator, any electronic supplier will have it.
Same as for the 7805: any electronic supplier will have them.
It'll be the main part of the bracket. Personally I've chosen 25*25*2 mm aluminum angle.
So, you should have something like this (yes, I forgot the capacitors and bolts for the picture...):
Bidule0hm
Reserved.
Bidule0hm
The build
First you'll need to drill all the holes in the aluminum angle: 2 holes for the PCIe connector, one for the LM7805 and 2 for the SSD (plus 2 others if you want to tie-wrap the power cable to the angle for strain relief); of course the holes positions will depend on your particular MB, how you want to put the SSD, etc. Then you'll need to clean the angle (metal filings and delicate electronics don't go well together... :D).
Next you'll need to fasten the PCIe connector (see below for more details) and then the LM7805, don't forget to put some thermal paste between the 7805 and the angle. NB: the angle needs to be aluminum because of his very good thermal conductivity. As you can see I placed the 7805 at the right place so the input pin (see below for the schematic diagram and the PCIe slot pinout) can be directly soldered on the right pads of the PCIe connector:
Then solder the capacitors and the wires of the SATA power connector:
Add some heat-shrink tubing for good measure:
And a bit of hot melt glue just to be sure:
Here you can see better how the PCIe connector is fixed to the angle: there's two washers used as spacers and I isolated the connector solder pads from the angle with some electrical tape just to be sure:
The schematic diagram:
The PCIe slot pinout:
Bidule0hm
Reserved.
Bidule0hm
A little mistake...
You may have seen that I made a mistake:
That's why you want to double check and triple check an electronic circuit before applying power :)
Of course I fixed it; simply by cutting the trace just right next to the "LDF" text.
There's no problem on the back side as the washer is smaller. On the other side there's also no problem as the leftmost trace is a ground trace.
Bidule0hm
Reserved.
Bidule0hm
The result
Some pictures of the end result:
Bidule0hm
Reserved.
Bidule0hm
Reserved.
Chris Moore
Can you fix the photos for this? They are not showing up for some reason.
Very interesting. Any reason why you didn't just install an insulator layer between the pcb and the angle? Even without a lot of weight it is possible that stress and vibration could cause the pcb to break allowing things to shift. Using a thin piece of rubber or even hot glue on the back side of the PCB would allow a larger surface without a gap to spread the stress out a bit.
Bidule0hm
@Chris Moore they are showing up perfectly here but I'll try at work tomorrow to be sure ;)
@nightshade00013 There's an insulator (3 layers of electrical tape) plus the PCB is spaced from the angle by washers (you don't want to put pressure on the board and so on the insulator so you don't puncture it and you don't bend the board), it's visible on this picture. Of course it's not supra hypra robust mechanically speaking but it's also because I don't have a standard case so I don't have PCI slot bracket support. In a standard case you can easily change some things (add an old PCI card bracket for example) to be able to screw the thing to the case like any other PCI card and not have to worry about that. This thread is really to share the base idea and to show how I made it but there's literally a ton of things you can change to suit your needs :D
gpsguy
Active Member
What browser are you using? Are you running any extensions?
I am in my phone right now, but can see them with Tapatalk.
Dice
Pics work fine on Chrome.
cool project.
Bidule0hm
Yep, I can confirm they works at my work too ;)
Chris Moore
Sorry, It is probably the place I work blocking the site that hosts the images.
