Hi guys
I struggling with some performance problems which I think are related to the network.
This is the speed of my RAIDZ:
nas# dd if=/dev/zero of=/mnt/tank/polycom/testfile bs=8192k count=1000
1000+0 records in
1000+0 records out
8388608000 bytes transferred in 58.916148 secs (142382153 bytes/sec)
So I get around 140Mb/sec.
And this is the speed from my Macbook Pro 2011 to my Freenas RAIDZ using AFP (SMB is a tini bit slower):
niks-macbook-lan:~ nisele$ dd if=/dev/zero of=/Volumes/polycom-4/testfile bs=8192k count=1000
1000+0 records in
1000+0 records out
8388608000 bytes transferred in 245.361209 secs (34188811 bytes/sec)
I get around 30-34Mb/sec.
I believe via a Gigabyte network adapter I should easily be able to get network transfer speeds beyond 100Mb/sec. Or is that impossible?
Any suggestions how I can boost the network speed?
Btw. this has been tested via a direct link using Cat6 cable.
Cheers,
Nik
1000+0 records in
1000+0 records out
1000+0 records in
1000+0 records out
Cheers,
Nik
